EAP-PEAP authentication fails after upgrading ClearPass
  • 1.  EAP-PEAP authentication fails after upgrading ClearPass
    Posted Mar 28, 2016 04:47 PM
    After upgrading ClearPass from 6.4.3 to 6.5.5, all EAP-PEAP  authentications are failing, even for domain machines. While EAP-TLS is working. Here are some of the logs:
    INFO RadiusServer.Radius - rlm_mschap: Domain corpdomain.com from User-Name does not match domain CORP from Object SID
    INFO RadiusServer.Radius - rlm_mschap: authenticating user LP14$, domain corpdomain.com
    INFO RadiusServer.Radius - rlm_mschap: user LP14$ authentication failed
    ERROR RadiusServer.Radius - rlm_mschap: AD status:Access denied (0xc0000022)
    ERROR RadiusServer.Radius - rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
    INFO RadiusServer.Radius - rlm_mschap: Using domain CORP from User-Name attribute
    INFO RadiusServer.Radius - rlm_mschap: authenticating user username, domain CORP
    INFO RadiusServer.Radius - rlm_mschap: user username, authentication failed
    Tried to make Netbios name  equal to domain name, enabling user-stripping, enabling always using Netbios name.. No luck
    Any ideas?
  • 2.  RE: EAP-PEAP authentication fails after upgrading ClearPass
    Posted Mar 28, 2016 05:07 PM
    Are you able to LDAP browse ? Under your AD source
    Configuration > Authentication > Sources > Primary
  • 3.  RE: EAP-PEAP authentication fails after upgrading ClearPass
    Posted Mar 28, 2016 05:09 PM
    Yes.
  • 4.  RE: EAP-PEAP authentication fails after upgrading ClearPass
    Posted Mar 28, 2016 05:19 PM
    You should open an Aruba TAC case in parallel so they can take a look.
    Have you tried remove/readding CPPM to the Domain ?
  • 5.  RE: EAP-PEAP authentication fails after upgrading ClearPass
    Posted Mar 28, 2016 06:07 PM
    No I didn't try re-joining
    I just tried in the CLI: ad testjoin and the result:  Preauthentication failed. Join to domain is not valid: Logon failure
    I'll re-join and update you at the earliest.
    Update: re-join the AD domain solved the issue.
    I'm just curious though, what would be the cause of this?
    Thanks for your fast response.
  • 6.  RE: EAP-PEAP authentication fails after upgrading ClearPass
    Posted Jan 05, 2017 08:43 AM
    I SSH'd into my servers and ran "ad passwd reset -n DOMAIN" which fixed it for me without needing to re-join the domain.
