EAP-PEAP using public certificates with no warnings
  • 1.  EAP-PEAP using public certificates with no warnings
    Posted Mar 07, 2015 03:42 AM
    Hi!
    Is it possible to achieve no warnings on a 802.1X SSID using EAP-PEAP with a publicly signed certificate on the RADIUS server for all devices? Including macbooks, ios, win8.1 etc? I would want this to be without touching the devices at all or pre-populating the server certificate manually.
    My experience is that if I use a publicly signed certificate, issued to the hostname of the RADIUS server some devices will accept this without warning the first time but many won´t. For example all apple devices will complain, it will say that the certificate is valid, but that it couldn´t validate it. Of course it´s hard to validate a certificate without being authenticated in the first place.
    So how do we solve this? Is there a neat trick that I don´t know about? :)
    Have a great weekend all!
  • 2.  RE: EAP-PEAP using public certificates with no warnings
    Posted Mar 07, 2015 04:09 AM
    The short answer is no...
    The problem you will also start running into is that most public CA will no long issue a radius cert that is publicly signed as Nov 2015.
    Using a cert that is publicly signed is a major security risk and the CAs do not want to be responsible for admins just trying to make it easy on the users. You are opening up you network to a man in the middle attack.
    http://blog.depthsecurity.com/2010/11/when-8021xpeapeap-ttls-is-worse-than-no.html
    Michael post some great links from the CAs
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/CPPM-different-radius-server-cert-for-different-services/m-p/209025/highlight/true#M15933
  • 3.  RE: EAP-PEAP using public certificates with no warnings
    Posted Mar 07, 2015 04:32 AM
    I love that blog post, thanks for sharing!
    I Guess if you´re facing tons and tons of BYOD, no budget for Onboarding and you want role derivation depending on what type of user is logging in I´ll have to advice a self signed certificate with warnings?
    Of course after informing the customer about the potential risk this proposes as per the blogpost. It doesn´t feel very good :/
