EAP-TEAP minimum AOS version
This thread has been viewed 27 times
  • 1.  EAP-TEAP minimum AOS version
    Posted Jan 19, 2023 08:35 AM
    Hello everybody,
    I am not able to find out if there is a minimum AOS version required on the WLC to support EAP-TEAP for connected Windows Laptops.
    We have one installation with 8.6 where it is working properly, but we are failing to let it work on a WLC in 6.5.4.24.
    Many thanks
    Kind regards
  • 2.  RE: EAP-TEAP minimum AOS version
    Posted Jan 19, 2023 04:53 PM
    from memory I think it was introduced around AOS 8.6, so for sure not in 6.5.x firmware
  • 3.  RE: EAP-TEAP minimum AOS version
    Posted Sep 11, 2023 03:24 AM
    Is it possible to get this from official documentation instead of going from memory.  We have 180+ sites and we would like to be absolutely sure which version we need for TEAP.  Thanks
  • 4.  RE: EAP-TEAP minimum AOS version
    Posted Sep 11, 2023 11:45 AM
    Support was added in 8.6, definitely not in 6.5.4, not sure why a statement wasn't added to the Release Notes.
    Note, at this time you should be moving to 8.10 as 8.6 is going EOS in November.
    Carson Hulcher, ACEX#110
