EAP-TLS authentication error-iOS devices
  • 1.  EAP-TLS authentication error-iOS devices
    Posted 2 days ago
    Im getting below error when trying to connect to wifi. . CA root certificate already in trusted list cleparpass.
    2024-07-25 14:05:00,610 [Th 56 Req 2631380 SessId R0004c697-06-66a23f6c] ERROR RadiusServer.Radius - TLS Alert read:fatal:certificate unknown
    2024-07-25 14:05:00,610 [Th 56 Req 2631380 SessId R0004c697-06-66a23f6c] ERROR RadiusServer.Radius - TLS_accept:failed in error
    2024-07-25 14:05:00,610 [Th 56 Req 2631380 SessId R0004c697-06-66a23f6c] ERROR RadiusServer.Radius - rlm_eap_tls: SSL_read failed inside of TLS (-1), TLS session fails. error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown
    2024-07-25 14:05:00,610 [Th 56 Req 2631380 SessId R0004c697-06-66a23f6c] ERROR RadiusServer.Radius - rlm_eap_tls: TLS Handshake failed
  • 2.  RE: EAP-TLS authentication error-iOS devices
    Posted 2 days ago
    Either the trust of the client certificate isn't configured properly on the RADIUS server or the trust of the RADIUS certificate isn't correct on the client device.
    Carson Hulcher, ACEX#110
  • 3.  RE: EAP-TLS authentication error-iOS devices
    Posted 2 days ago
    Check what cert is used if any for authentication of the connection. And also CA subordinate cert if it is used for signing into trust list. Don't forget to select EAP for usage on both certs.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
