EAP-TLS authentication with Authorization Request enalble
  • 1.  EAP-TLS authentication with Authorization Request enalble
    Posted Oct 20, 2015 10:49 AM
    I am using EAP-TLS authentication on Clearpass. If Icheck Authorization Request as enable, the EAP-TLS authentication will fail. If I uncheck Authorization Request, the EAP-TLS authentication will pass. Can someone tell me what the Authorization Request really does please?
    Thank you.
  • 2.  RE: EAP-TLS authentication with Authorization Request enalble
    Posted Oct 20, 2015 10:52 AM
    It checks the username on the certificate with a database like AD to ensure it exists.
  • 3.  RE: EAP-TLS authentication with Authorization Request enalble
    Posted Oct 20, 2015 01:02 PM
    Though the username (CN on the certificate) is in AD, why I still cannot pass the EAP-TLS authentication with Authorization Request checked?http://community.arubanetworks.com/t5/forums/replypage/board-id/aaa-nac-guest-access-byod/message-id/22993#
    Many thanks!
  • 4.  RE: EAP-TLS authentication with Authorization Request enalble
    It's used to validate against another authentication source. The Onboard respository for example.
  • 5.  RE: EAP-TLS authentication with Authorization Request enalble
    Posted Oct 20, 2015 10:59 AM
    Many thanks, Tim, for your reply. It is Authorizaton Request as its name indicates. Why do you say it is another authentication?
  • 6.  RE: EAP-TLS authentication with Authorization Request enalble
    Posted Oct 20, 2015 11:00 AM
    In many cases, authentication sources are used as authorization sources....
