EAP-TLS in VIA
  • 1.  EAP-TLS in VIA
    Posted Feb 18, 2013 03:20 AM
    Hi all.
    I have a couple of questions about using EAP-TLS with Aruba VIA.
    Can I use EAP-TLS (or user-cert) as authentication for profile download (VIA Web Authentication)?
    Also, will the VIA client check personal certificates for both user and machine, or just for user?
    Thanks!
    -Nesvik
  • 2.  RE: EAP-TLS in VIA
    Posted Feb 18, 2013 08:24 PM
    - No, you cannot use certificates for the basis of web authentication profiles.
    - VIA will only look for user-based certificates during authentication; not machine-based.
  • 3.  RE: EAP-TLS in VIA
    Posted Feb 19, 2013 03:00 AM
    Thanks for the quick response, clembo!
    Too bad that the VIA client cannot use Machine-based certificates.
