EAP-TLS machine authentication
  • 1.  EAP-TLS machine authentication
    Posted Aug 27, 2018 11:32 AM
    Hi Guys,
    I am setting up an eap-tls lab with  IAPs, Clearpass and some windows machines.
    I wanted to know:
    - After clearpass authenticates the machine with its certificate, what would be the tls tunnel endpoints? in other words, if the authentication is between clearpass and the windows machines, will the tunnel be established between clearpass and the machines or between the IAP and the machines?
    - in case both machine and user authentication are implemented, is the user traffic going to be encrypted using the user certificate or the machine certificate?
    - in case only the machine authentication is implemented, what traffic is going to be encrypted via the TLS tunnel?
    Thanks in advane for any clarification
  • 2.  RE: EAP-TLS machine authentication
    Posted Aug 27, 2018 11:35 AM
    The TLS session is between the supplicant (client) and authentication server (ClearPass).
    The only relationship between the authentication session and encryption is key derivation for WPA2-Enterprise.
