EAP TLS SSO
  • 1.  EAP TLS SSO
    Posted Apr 07, 2014 05:51 PM
    Has anyone done any workaround for this?
    I got a clietn which need to do a SSO  like with  EAP PEAP which is possible.
    He runs a scritp  but the device need to authenticate before the user log in, in windows... it need to run a script the scritp, and if it does not have the single sign on, the script cannot run because is not int he network yet..
    When he had SSO with EAP PEAP with single sign on configured on windows supplicant,  everything worked pretty good but now that he moved to EAP TLS for more security, now the EAP TLS lack of Single sign on on the windows suplicant  like it says on microsoft document http://support.microsoft.com/kb/2717916
    Has anyone encounter this issue? any workd aroudn for it?
    Cheers
    Carlos
  • 2.  RE: EAP TLS SSO
    Posted Apr 07, 2014 09:56 PM
    You can use EAP-TLS with machine authentication.
  • 3.  RE: EAP TLS SSO
    Posted Apr 23, 2014 01:28 PM
    Hello Collin
    If i do eap tls with machine authentication that means i would need to enable the machine authentication on the controller?
    Cheers
    Carlos
  • 4.  RE: EAP TLS SSO
    Posted Apr 24, 2014 05:27 PM
    Anyone???
    Cheers
    Carlos
  • 5.  RE: EAP TLS SSO
    Posted Apr 24, 2014 05:34 PM
    No.
    You do not need to configure anything on the controller, except define a radius server.  On the radius server is where you decide what users or machines to allow authentication based on AD Groups.
  • 6.  RE: EAP TLS SSO
    Posted Apr 24, 2014 05:35 PM
    Thank you
    Ill do some testing then
    Cheers
    Carlos
  • 7.  RE: EAP TLS SSO
    Posted May 05, 2014 04:40 PM
    Hello Collin
    I tested and it seems to work!
    2 More questions
    1-There is no way to make the name rather than the computer name on the client list? when authenticating with the computer?
    host/pcname.domain.local
    2-The only way to authenticate computer AND the user name its by using the feature of the controller of machine authentication?
    Cheers
    Carlos
  • 8.  RE: EAP TLS SSO
    Posted May 05, 2014 04:51 PM
    @NightShade1 wrote:
    Hello Collin
    2 More questions
    host/pcname.domain.local - You would have to distribute a Client Certificate to each computer and allow user and computer authentication.  Unfortunately, each user would have to had logged into the computer once on the wired network to obtain an EAP-TLS certificate before getting onto the wireless for the frist time.
    2-The only way to authenticate computer AND the user name its by using the feature of the controller of machine authentication?  - You  can using group policy setup the computer to authenticate the user and computer without configuring anything on the controller.  The user would have to already have had an eap-TLS certificate distributed to the machine, like I mentioned in question #1.
    Cheers
    Carlos
  • 9.  RE: EAP TLS SSO
    Posted May 05, 2014 05:12 PM
    Hello Collin
    On the computer i do have a user certificate
    on  mmc-->add snap in --->Certificate add ---> my user account---> con personal folder, i already got  a certificate for user which is using a client authentication template
    Also i already got a computer certificate
    on  mmc-->add snap in --->Certificate add ---> my computer account---> con personal folder, i already got  a certificate for computer which is using a machinet authentication template
    On the configuration on my computer i got authenticate user or computer authetnication.
    Where do i tell it to authenticate Machine AND user
    On the radius server?
    On network policiy do a build one single rule which contain one condition which contains the domain users
    And another condition which contain domain computers?
    If i test it individually i mean just computer authetnication works fine... or just user authentication....
    Cheers
    Carlos
  • 10.  RE: EAP TLS SSO
    Posted May 05, 2014 05:15 PM
    @NightShade1 wrote:
    Hello Collin
    Where do i tell it to authenticate Machine AND user - You only need to allow it on the radius server.
    On the radius server? The radius server only uses the username from the certificate, so as long as you are allowing logins from the AD group of the user, it should allow you to authenticate
    On network policiy do a build one single rule which contain one condition which contains the domain users - Correct.
    And another condition which contain domain computers?  Correct x2
    Cheers
    Carlos
  • 11.  RE: EAP TLS SSO
    Posted May 05, 2014 05:36 PM
    Hello Collin
    The machine authentication doesnt seems to work if i dont put onthe client  on specify authentication mode computer authentication
    If i for example on the on my computer i put user or machine authentication
    And on the radius server i put just a condition to machine authenticate it doesnt work
    I have to put on my computer machine authentication only
    If i put both conditions separetaly like this:
    And i put on my computer user or machine authentication it does not work....
    If i put a single rule on the radius server which refer to domain user group
    And on my computer i put user or machine authentication then it works....
    I fail to make both authenticate.... but i can do it individually.... :(
