EAP-TLS testing
  • 1.  EAP-TLS testing
    Posted Mar 14, 2018 05:42 PM
    Hi All,
    We are testing EAP-TLS in our wireless.
    We have 72xx controller with AP325.  The controller is running 6.5.3.3.
    clearpass in v6.6.8
    Current we have the hybrid in our eduroam, serving both PEAP, and EAP-TLS.  My IOS devices able change from PEAP to EAP-TLS no problem and it works.  After connecting my IOS devices, EAP-TLS I have no problem stay connected and access Internet.  However occasional I am experiencing that my wireless will not reconnect or auto join back after roaming.  I have to go to setting and clicks on eduroam to join.  Not sure if anyone is also experiencing the similar thing.  ANy suggestion is greatly appreciated.
    SL
  • 2.  RE: EAP-TLS testing
    Posted Mar 14, 2018 06:00 PM
    Are you using the same EAP server certificate across all of your RADIUS server nodes?
