I don't agree with that statement. EAP-TLS (or EAP-TEAP) should be used to authenticate all users (where feasible).
Personally, I don't have this experience with NPS, but you can request a (user) certificate manually from your ADCS (or other CA) and install that on non-domain joined clients. In the real world, for somewhat larger than really small, you want to automate that process, in which case a MDM/EMM (Mobile Device Management) solution can help in getting the certs deployed automatically to devices that you can bring under its control. For non-managed devices, you could have a look at ClearPass Onboard to get the certificate requested and installed in a simple-to-follow procedure for the user.
Original Message:
Sent: Jul 06, 2021 01:13 AM
Subject: EAP-TLS with NPS
To have EAP-TLS authentication client should have certificate installed on his computer and it should be domain machine.
As per my understanding eap-tls is not a recommended way to authenticate non domain users.
Original Message:
Sent: 7/5/2021 12:09:00 PM
HI Airheads,
we have a customer with Aruba AP's and controllers (V8).
They have NPS for a RADIUS server and they want to do EAP-TLS to NPS with NON-AD clients.
I was wondering is there a way of authenticating clients with EAP-TLS that are not AD members?
I know i have to consider revocation but just want to get EAP-TLS going to begin with.
regards
Pete
Pete Elms
