  • 1.  EAP-TLS with Windows not working with SCEP Certificates
    Posted Jul 24, 2024 12:01 PM
    Hey guys,
    So I am testing a new deployment option with an Azure based CPPM with Onboard + Intunes SCEP extension. The solution has successfully deployed client certificates to my windows devices.
    I am manually configuring the WiFi and I have not been able to get the devices to authenticate. In theory EAP-TLS I do not need an authentication source as I only want to trust the certificate. Next step will be adding Entra account validation, but still stuck on the basic authentication step.
    Authentication fails with the following error:
    EAP-TLS: fatal alert by server - unknown_ca
    TLS Handshake failed in SSL_read with error:1417C086:SSL routines:tls_process_client_certificate:certificate verify failed
    eap-tls: Error in establishing TLS session
    The client is selecting the right cert, which was created by the Onboard CA and it also has the root cert as a Trusted CA.
    The Onboard CA ROOT cert is in the CPPM trust list and set the EAP and Others for the usage. I cannot figure out why it is reporting "unknown_ca".  I have tried disabling "verify the server identity" on the client side, but that didn't change anything
    Service is using EAP-TLS authentication method with authorization disabled. CPPM is on version 6.12.2. Client does have a TPM chip, but the error seems unrelated.
    Any ideas?
    RK
  • 2.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Jul 24, 2024 12:36 PM
    Nevermind, found my mistake. Will publish results in a bit.
    vs.
  • 3.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Sep 17, 2024 09:39 AM
    Hi !
    So what was that?
  • 4.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Mar 07, 2025 10:30 AM
    What was the fix mate
  • 5.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Nov 02, 2024 12:05 AM
    How did you fix this? can you help us finding the cause?
  • 6.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Nov 05, 2024 08:37 AM
    If the message in Access Tracker is: "EAP-TLS: fatal alert by server - unknown_ca"; then the problem is that ClearPass (by server) does not trust the client certificate (unknown_ca). Which either is that you didn't install the correct Client Issuing CA (root and possibly the intermediates) in the ClearPass Trust List, or it doesn't have the 'Usage: EAP or RADIUS' in the Trust List.
    Or the client doesn't select the correct certificate and tries with another certificate.
    Maybe RKinsp can tell what was the case here.
  • 7.  RE: EAP-TLS with Windows not working with SCEP Certificates
    Posted Nov 05, 2024 08:41 PM
    Hi any update on your deployment? Interested to know if you're using the new MS PKI service. Also did you have any issues deploying the CPPM appliance?
