  • 1.  EAP-TLS without onboarding licenses
    Posted Oct 18, 2019 10:02 AM
    Dear Experts,
    One of the customer is exploring the option of using certificate based authentication. Is it possible to do certificate management from Active directory CA (or some other CA) and only do the authentication from Clearpass. If yes, will it still need onboarding licenses?
  • 2.  RE: EAP-TLS without onboarding licenses
    Posted Oct 18, 2019 10:10 AM
    Yes, won’t need onboard licenses if ClearPass is not acting as the CA
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: EAP-TLS without onboarding licenses
    Posted Oct 18, 2019 10:38 AM
    Can you also highlight will the process of onboarding client will remain
    the same?
    Like directing them to a webpage and configuring their 802.1x settings via
    quick connect tool?
  • 4.  RE: EAP-TLS without onboarding licenses
    Posted Oct 18, 2019 01:37 PM
    Yes you can use a dual Onboarding workflow and configure the necessary policies to provide access to Onboarding devices vs devices using ADCS issued certificates
    Thank you
    Victor Fabian
  • 5.  RE: EAP-TLS without onboarding licenses
    Posted 16 days ago
    Kindly share the process
    regards
    avanindra
  • 6.  RE: EAP-TLS without onboarding licenses
    Posted 15 days ago
    Please share the steps
  • 7.  RE: EAP-TLS without onboarding licenses
    Posted 6 days ago
    You responded to a very old post that is about different methods of EAP-TLS where if you use Onboard or the ClearPass CA, Onboard licenses are needed, if you deploy certificates fully independent of ClearPass, you don't. What 'steps' are you looking for?
    How to setup EAP-TLS and/or ClearPass Onboard is part of every ClearPass training. Your HPE Aruba partner should have this knowledge.
