This thread has been viewed 24 times
  • 1.  EAP/TLS 1.2?
    Posted Jul 27, 2015 01:27 PM
    It seems the new osx 10.11 is only supporting TLS 1.2 which we currently don't have enabled on our 802.1x network. We terminate on our controller and not the a Radius server currently, anyone know of a way to enable TLS 1.2 on 6.4 code? Looking into this it seems since 6.1 this has been supported however in newer documentation I can't find anything about this and these commands aren't on 6.4 code.
    Support for TLS 1.2
    The AAA FastConnect authentication mechanism has been enhanced to support TLS protocol version 1.2. This support allows you to use the Suite B cryptographic algorithms. By default the TLS 1.2 protocol is
    disabled. Use the aaa authentication dot1x new-eap-termination commandto enable TLS 1.2 support.
    Using CLI to Enable TLS 1.2:
    aaa authentication dot1x default-eap-termination
    enforce-suite-b-128
    enforce-suite-b-192
    Where, the enforce-suite-b-128 option enables 128-bit security level and the enforce-suite-b-192enables the 192-bit security level.
  • 2.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 01:39 PM
    Those relese notes refer to suite b encryption for users who have purchased an enable the ACR or advanced encryption license.  Those are typically government and highly secure installations.  Most users do not have that license.
    If you are not using termination, only your radius server needs to support TLS 1.2
    If you are using Termination, TLS 1.2 support is enabled in:
    6.4.3.3 - Released 7/24/2015
    6.4.2.9 - Released 7/12/2015
    6.3.1.x - Not released as of yet
    The bug in the 6.4.3.3 release notes is below:
    The versions above support TLS negotiation to 1.2, so they should support the latest IOS beta 9 and MAC OSX change.
  • 3.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 01:43 PM
    I tested on the latest 6.4.2.10 is that not supported as well? What commands do we need to do to enable TLS 1.2 if we don't have ACR or advanced encryption license?
  • 4.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 01:51 PM
    The short term solution if you choose to support beta software is to terminate on your TLS 1.2 RADIUS server.
    Tim
  • 5.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 01:53 PM
    Well we understand its beta and we don't support it either however if it's something apple pushes out in the final release only allowing TLS 1.2 we'd be screwed at the moment, currently I don't have controll over our radius servers as thats a different department and will go that route if it's necessary so right now would like to find out how to support it while terminating on the controller as we do now.
  • 6.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 02:07 PM
    flava,
    No commands should be needed to enable TLS 1.2.  According to the bug, the controller should now be able to negotiate with EAP-TLS 1.2 whereas it could not before.
    I suggest you open a TAC case to make sure everything is configured properly in your setup. If you have a lab, it would be advisable to stage things there to ensure you have no gaps in your strategy.
  • 7.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 03:47 PM
    Will TAC even support this even though current release of osx 10.11 is in beta?
  • 8.  RE: EAP/TLS 1.2?
    Posted Jul 27, 2015 03:51 PM
    The fix was put in due to the change. They should be able to handle this based on the fix.
  • 9.  RE: EAP/TLS 1.2?
    Posted Oct 09, 2015 04:34 PM
    Android 6.0 (Marshmallow) has this issue too by the look of it.
    https://code.google.com/p/android/issues/detail?id=188867
    Cory C.
    Ohio University.
  • 10.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:34 AM
    We have the same issue here with Marshmallow.
    Any fix known ?
  • 11.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:36 AM
    Are you using EAP-TTLS?
  • 12.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:38 AM
    no, eap-mschapv2
  • 13.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:39 AM
    What is your radius server?
  • 14.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:40 AM
    What version of ClearPass?
    On 6.5.2+, this issue is only present for EAP-TTLS.
  • 15.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 09:42 AM
    Sorry , my mistake, we do not use clearpass.
    I guess i will check with the people who put the radius on line.
  • 16.  RE: EAP/TLS 1.2?
    Posted Oct 21, 2015 10:04 AM
    Gerry_uottawa,
    The radius server is the key here.  If the controller is not doing termination, they are just passing everything through to the radius server, which might not support TLS 1.2
  • 17.  RE: EAP/TLS 1.2?
    Posted Nov 03, 2015 05:23 PM
    EAP-TTLS with ClearPass and TLS 1.2 seems to be fixed in ClearPass 6.5.4... https://twitter.com/arjan_k/status/661658617314213892
  • 18.  RE: EAP/TLS 1.2?
    Posted Nov 03, 2015 05:27 PM
    Hi all,
    We actually fixed the issue with TAC yesterday.
    We had to upgrade all controllers to 6.3.1.18.
    All good now.
  • 19.  RE: EAP/TLS 1.2?
    Posted Nov 25, 2015 09:13 AM
    It seems that in a new Build for Windows 10 1511 - 10586 they are changing a setting for EAP TLS 1.2
    We have Aruba version 6.4.3.3 which we upgraded to resolve the above mentioned issue.   We terminate on the controllers for our Primary SSID and users are unable to connect.  If they use  "eduroam" which is terminated on the Clear Pass servers they have no issues.  The following link describes a work around of disabling EAP TLS 1.2 in the Registry which I believe allows them to connect but have not verified myself yet  <http://answers.microsoft.com/en-us/windows/forum/windows_10-networking/after-update-to-1511-i-cant-connect-via-wlan-to-my/696f12ed-6e08-4e14-ae30-c7a878ebbd17?auth=1>
    Also I have read that Microsoft has pulled this build and is adding the changed to be pushed out as part of monthly patches.     I do have a case for this and am working to get captures to the TAC.      Anyone else see this problem?          Not sure if this should have been a new post or not.
    Chris Hart
    Norhtwestern University.
  • 20.  RE: EAP/TLS 1.2?
    Posted Nov 25, 2015 10:51 AM
    Sounds like this just adds Win10 to the list of systems that default to TLS1.2 by default.  If your local users are authenticating successfully via ClearPass, I think you just need to:
    1) update the controllers
    -or-
    2) remove termination from SSIDs and enable it on ClearPass for those SSIDs.
    We went with option 2 though we use NPS instead of ClearPass.
    Cory C.
    Ohio University
  • 21.  RE: EAP/TLS 1.2?
    Posted Nov 26, 2015 06:12 AM
    We have the same issue at a customer.
    Terminating EAP on the controller (6.4.2.13)
    Win10 clients with all patches can´t connect.
    The registry patch is a valid workaround.
    Will this be fixed in 6.4?
    Christian
  • 22.  RE: EAP/TLS 1.2?
    Posted Nov 26, 2015 07:45 AM
    You should consider terminating on your RADIUS server.
    Sent from Nine
  • 23.  RE: EAP/TLS 1.2?
    Posted Nov 30, 2015 09:23 PM
    I found this that give more details of the issue from Microsoft
    https://support.microsoft.com/en-us/kb/3121002
    Also note that I am at Aruba OS 6.4.3 and have the issue.
    Chris Hart
    Northwestern University
  • 24.  RE: EAP/TLS 1.2?
    Posted Dec 09, 2015 04:59 PM
    Model: Aruba650
    Version: 6.4.2.2
    I have an open ticket with Aruba and i'm using the controller with internal authentification and i'm having issue with Windows 10 with november patch and Android 6.0.
    Temporary fix fox Windows 10(Downgrade TLS version):
    REG add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RasMan\PPP\EAP\13" /v TlsVersion /t REG_DWORD /d 192 /f
    net stop EapHost
    net start EapHost
    Android : No Fix
    Here is the support message :
    "The controller does not support TLS 1.1 and TLS 1.2 on the version the controller is running, thus we are facing this issue. There is no way to disable or enable it on the controller for now. However, I am tracking the engineering ticket. Will keep you posted on this."
    Waiting for them !
  • 25.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 08:37 AM
    We are at the same stage here.
    Even though the Microsoft fix works, it is not an options when you have 60 000+ users.
    Waiting for TAC to get back to me.
  • 26.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 08:38 AM
    Same here.
    Also have a case open.
    Christian
  • 27.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 08:50 AM
    @Gerry_uottawa wrote:
    .....it is not an options when you have 60 000+ users.
    Are you saying you are doing EAP termination of 60,000+ users on the controllers?    I would advise against that and use termination on your RADIUS servers.
    Please share how things go with TAC.
  • 28.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 08:52 AM
    no, the termination is done on the Radius, not on the controllers.
  • 29.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 08:59 AM
    Does your RADIUS server support TLS 1.2? If you're not doing termination on the controller and your RADIUS server is up to date, Win 10 shouldn't have any issues connecting.
  • 30.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 09:18 AM
    EDIT:
    what Tim said ;-)
    If termination is not done on your controllers, does your RADIUS server support TLS 1.2?    What RADIUS solution are you using?   If you are not terminating on the controller and the server supports TLS 1.2, you should not have these specific authentication issues.
  • 31.  RE: EAP/TLS 1.2?
    Posted Dec 10, 2015 09:20 AM
    I personally don't access access to the Radius.
    I just know that it runs on Windows 2008 R2 and has been patch about 10 days ago.
    I am waiting for the Sys Analyst to check why we are having that kind of issue.
  • 32.  RE: EAP/TLS 1.2?
    Posted Dec 12, 2015 01:19 PM
    Seems Android 6.0.1 has a workaround for broken Radius Servers.
    https://android.googlesource.com/platform/frameworks/opt/net/wifi/+/eb5caea
    Christian
