SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
EC-10104 with 3 WAN
  • 1.  EC-10104 with 3 WAN
    Posted Jan 31, 2024 02:18 PM
    We want to implement Aruba SDWAN Edgeconnect EC-10104 device with 2 WAN inet1 and inet2 and a 3rd WAN (LTE) that will be the backup.
    Is it something possible with the EC-10104 model ?
    Many thanks by advance for your help.
  • 2.  RE: EC-10104 with 3 WAN
    Posted Feb 01, 2024 01:11 AM
    Yes the 10104 has 4x copper Ethernet ports. You can use 3x ports for INETA, INETB, and LTEA then the fourth port for lan-side connectivity. If you have 2x 10104s in an EdgeHA pair you get 6 effective ports (one port on each 10104 used for EdgeHA link). You can then have INETA on 10104-Primary and INETB/LTEA on 10104-Backup.
  • 3.  RE: EC-10104 with 3 WAN
    Posted Feb 01, 2024 01:28 AM
    Many thanks for your answer. I can see there are 4 ports, 2 LAN and 2 WAN. Do you mean we can use one of the LAN ports as the 3rd WAN ?
  • 4.  RE: EC-10104 with 3 WAN
    Posted Feb 01, 2024 10:25 AM
    Yes, you can use one of the LAN ports as a WAN interface. In the deployment page, add a new WAN interface and, for instance, select 'lan1' under the interface.
    Technically, you can use any interface except 'mgmt' for LAN and WAN, regardless of their label on the appliance.
  • 5.  RE: EC-10104 with 3 WAN
    Posted Feb 01, 2024 10:26 AM
    Yes, You can use LAN Ports as WAN Ports (and WAN ports as LAN ports). These labels on the hardware for general indication only.
  • 6.  RE: EC-10104 with 3 WAN
    Posted Feb 01, 2024 11:35 AM
    Thanks all for your help !
