I am trying to find out the ECCN and HTS codes for AP-205-F1 and the DS7000 and DS7200 series mobility controllers
I believe for the AP it is HTS 8517.62.0050 ECCN 5A002.A.1. Is it the same for the controllers as well? Thank you for any help.
Picking a few at random...
Thank you. Would you know for 7010-RWF1, 7030-RFW1, 7030-JPF1, 7205-JPF1, 7205-RWF1, 7210-JPF1, 7220-JPF1, 7220-F1, 7240-JPF1, and CP-VA-500?
I tried looking all over the site, but couldn't find the information.
The controllers are all the same, so it's the same as what I already posted.
CP-VA-500 is software.. as far as I understand it, export control doesn't apply to that. There's no software SKUs listed in my spreadsheet anyway.
Correct, Bev confirmed there's no ECCN for software (Clearpass, AirWave, etc).
You stated there was no ECCN or HTS assigned to SW but how is this designated if the SW comes predeployed on an appliances (server) directly from Aruba?
Mark
APs and controller hardware have an associated ECCN/HTS code
Any hardware appliances (servers for Clearpass or AirWave) would use the ECCN/HTS of the server vendor (which we can get if/when needed if not retreivable from said server vendor). Aruba provides no ECCN/HTS for the software itself (Clearpass, AirWave, etc)
Hi Jerod,
Yes, could provide the ECCN and HTS for the DELL servres that have the 25k license CPPM deployed on it?
That list is here - http://i.dell.com/sites/doccontent/shared-content/solutions/en/Documents/HTS-ECCN-CCATS-Reference-Table-ver15-02.pdf
We have had different server models go out over the years, so it's best to look it up on this table based on the hardware model you have. Depending on when you received your server, it could be an R610, R620, or R630 which should all share the same ECCN.
