EdgeCore Swtiches Radius Dictionary for Aruba ClearPass
  • 1.  EdgeCore Swtiches Radius Dictionary for Aruba ClearPass
    Posted Nov 08, 2021 11:50 AM
    Hello team! ,
    someone know or advise where I can download the Radius dictionary for Edgecore Switches?
    We are looking dictionary for ES3528MF Switches.
    Kr.
    Daniel Banda
  • 2.  RE: EdgeCore Swtiches Radius Dictionary for Aruba ClearPass
    MVP GURU
    Posted Nov 08, 2021 01:53 PM
    You may need to work with TAC to see what they can do for you. If you know what the values are for the radius attributes, you can attempt to create them yourself. This might require you to also reach out to the switch vendor to obtain these.
    You can export any of the radius dictionaries in ClearPass, and modify the XML file. Once you do this, import the xml file to the radius dictionaries and give it a test.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
