Location Services
  • 1.  Editing beacon without meridian subscription
    Posted Jun 30, 2020 11:50 PM
    Hi, is Aruba beacon limited to meridian only ? Any other apps for editing beacon major minor ?
    #ArubaBeacons
    #ArubaTags
    #LocationServices
    #ALE
  • 2.  RE: Editing beacon without meridian subscription
    Posted Jul 01, 2020 01:25 AM
    It is possible to edit the major/minor of the Beacon broadcast from the Access Points (as of AOS 8.4). I don't believe you can edit the Meridian battery powered beacons without Meridian.
    Are you looking to do this with the AP BLE radio or the battery beacon?
  • 3.  RE: Editing beacon without meridian subscription
    Posted Jul 01, 2020 05:33 AM
    Hi, i've both of battery and AP BLE. On instant VC somehow after upgrade to 8.6 the beacon isn't detected even after BLE Operation Mode changed to beaconing mode.
  • 4.  RE: Editing beacon without meridian subscription
    Posted Jul 01, 2020 08:52 AM
    Delete the beacon and insert it again.
    We’ve run into the same issue.
    Ended up by a manual delete and insert of all faulty beacons (bad major
    minor). Seem’s to affect only beacons inserted before a date previous to
    november 2019 or before.
    Hope this help!
    Simon Rousseau
    Cordialement,
    Simon Rousseau, M. Sc.
    Président de RIOH inc.
    T: 438-830-6837
    C: simon@rioh.io
  • 5.  RE: Editing beacon without meridian subscription
    Posted Jul 03, 2020 01:14 PM
