Eduroam issues AP205
  • 1.  Eduroam issues AP205
    Posted Sep 16, 2016 09:04 AM
    Hi all, anyone experienced the following.
    Large campus network, running 6.4 code.
    Intermittent poor internet access only on 1 SSID (eduroam) and seems to be only on 205 series AP's. All other SSID's connect without issue.
    Very odd...
  • 2.  RE: Eduroam issues AP205
    Posted Sep 16, 2016 09:33 AM
    Is the SSID configuration the same as your other networks (with the exception of the ESSID)? Things like data rates, basic rates, etc.
    What encryption is in use?
  • 3.  RE: Eduroam issues AP205
    Posted Sep 16, 2016 11:32 AM
    Hi Tim, I believe this is 802.1x, other SSID's are the same I believe. Has worked for years it is a recent issue, seems to be with 2xx series AP's only.
  • 4.  RE: Eduroam issues AP205
    Posted Sep 19, 2016 02:46 AM
    Hi All,
    This issue from my testing is only seen on AP205's.
    Make the following change to “AP system profile” of all the AP-groups and change the “SAP MTU” size to ‘1500’.
    Seems by default no value is set. Making this change had an immediate, positive effect.
  • 5.  RE: Eduroam issues AP205
    Posted Sep 19, 2016 05:43 AM
    Stunshot, please open a TAC case.  This could be a bug or a configuration issue, but it is very hard to tell from the limited information that you provided.  TAC should be able to rule out a few things and ask you about others...
