Eliminating Chatty protocols
  • 1.  Eliminating Chatty protocols
    Posted Oct 31, 2012 12:07 AM
    When you want to eliminate chatty protocols it is recommened to apply this on ROLES you using? and ALSO on the ports on my controller
    For example for my ROLES i would do this:
    im building a firewall policy called Chatty protocols
    with these parameters
    for deny_mDNS
    any any udp 5353 deny
    for deny_SSDP_and_UPnP_acl
    any host 239.255.255.250 any deny
    any host 239.255.255.253 any deny
    for deny_netbios_acl
    ip access-list session-acl deny_netbios_acl
    any any udp 137 deny
    any any udp 138 deny
    for deny_client_acting_as_server_acl
    ip access-list session deny_client_acting_as_server_acl
    user any udp 68 deny
    So the firewall rule named Deny Chatty protocols woult be like this
    So on my roles would be something like this
    Role name: Aruba Users
    Inside that
    Firewall polices:
    1-Deny Chatty protocols
    2-Normal User ACLs
    I normally just had one firewall policy which was the user ACL for example where he was able to reach in the internal network and that kind of stuff... but i wanted to add also the part of elminating the chatty protocols...
    Now for the ports in my Wireless controller i would use a similar firewall policy  let say i named it blocked chattyprotocols
    for the wired part would be like this
    user any any permit
    I just want to know if im doing it right, it is correct the way im doing it?
    Cheers
    Carlos
  • 2.  RE: Eliminating Chatty protocols
    Posted Nov 02, 2012 12:25 PM
    I think you are doing it right, and you are definately on the right track. There's really two separate ACLs, and can be summarized by "User --> LAN" and also "LAN --> User", and they won't always be mirrors of each other and won't always match. The real trick, and is something that try as I might I can never keep a unified list, is what each site/network admin consideres 'chatty'. It's a very iterative process, but I consider your approach sound, as you will invariably make changes over time as stuff breaks :)
  • 3.  RE: Eliminating Chatty protocols
    Posted Nov 02, 2012 12:29 PM
    Thanks man Im trying to implement all aruba recommendations... i dont have them all right now but in the future i want to implement WLAN network with ALL aruba recommendations.
    Thanks for asnwering!
