email alert for down APs 7200 controllers
  • 1.  email alert for down APs 7200 controllers
    Posted Oct 30, 2018 11:23 AM
    Is there a way to set up an email alert for down APs via 7210 controllers?
  • 2.  RE: email alert for down APs 7200 controllers
    Posted Oct 30, 2018 11:32 AM
    I don't know the direct answer (I know, not helpful!) but we use Airwave for this purpose for our central Wireless Team (its an inbuilt feature).
    We also have an in-house built system that can alert local IT teams but this relies on SNMP polling of the AP status from the controller.
    Alexander
  • 3.  RE: email alert for down APs 7200 controllers
    Posted Oct 30, 2018 11:55 AM
    The Aruba controller cannot send emails for alerts.  You would need an external Network Management System like Airwave to be able to send an email.
  • 4.  RE: email alert for down APs 7200 controllers
    Posted Oct 30, 2018 12:00 PM
    Thanks folks. We have airwave aswell. How can I setup this in airwave for email alert?
  • 5.  RE: email alert for down APs 7200 controllers
    Posted Oct 30, 2018 12:02 PM
    It's under the System / Triggers menu.
    Alexander
  • 6.  RE: email alert for down APs 7200 controllers
    Posted Oct 30, 2018 12:25 PM
    Before that how can I link Airwave & the APS on the controller?
  • 7.  RE: email alert for down APs 7200 controllers
    Posted Oct 31, 2018 04:30 AM
    Basically its under Device Setup -> Add
    However I urge you to read the Airwave user guide.
    Page >124 covers adding devices manually in the 8.2.7 user guide.
    You will need to provide SNMP credentials aswell as SSH/telnet credentials and target ip of the controller. Associated APs will follow.
    Monitor read/only, is recommended.
    Do note that you will need a sufficient amount of licenses in Airwave.
