last person joined: 2 hours ago
Email alerts from ClearPass servers in a cluster
  • 1.  Email alerts from ClearPass servers in a cluster
    Posted Oct 16, 2013 01:44 AM
    Has anybody here successfully setup email alerts in ClearPass 6.1?
    From what i can see across two separate clients, i'm unable to get ClearPass to send email notifications out when the servers are clustered.
    I have setup the messaging server address details and also set the cluster wide parameters to notify my address. to test i have set the notification to INFO to ensure a trap is generated and then i login and logout.
    Still nothing happens.
    I've also done a packet capture on the ClearPass Publisher and can see no traffic to the SMTP server defined in the messaging server settings.
    Any ideas?
    Scott
  • 2.  RE: Email alerts from ClearPass servers in a cluster
    Posted Oct 16, 2013 01:47 AM
    Are you trying to do alerts in insight or the standard CPPM?
  • 3.  RE: Email alerts from ClearPass servers in a cluster
    Posted Oct 16, 2013 01:48 AM
    hi troy,
    at this stage just the system alerts from CPPM.
    scott
  • 4.  RE: Email alerts from ClearPass servers in a cluster
    Posted Oct 16, 2013 02:00 AM
    I dont have a 6.1 to test on. I know that it has worked in my lab since 5.2. I would just double check the setting.
    I did a quick test on my lab 6.2.2
    Policy Manager Server   Source  Level   Category        Action  Timestamp
    cplab.clearpassdemo.com (10.80.2xx.xxx   Admin UI        INFO    Logged in       None    Oct 16, 2013 00:51:24 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   Admin UI        WARN    Login Failed    None    Oct 16, 2013 00:51:18 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   Admin UI        INFO    Logged out      None    Oct 16, 2013 00:51:13 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   Admin UI        INFO    Logged in       None    Oct 16, 2013 00:49:07 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   ClearPass Updater       INFO    AV/AS Updates   Success Oct 16, 2013 00:39:06 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   Admin UI        INFO    Logged in       None    Oct 15, 2013 23:16:32 CDT
    cplab.clearpassdemo.com (10.80.2xx.xxx)   ClearPass Updater       INFO    AV/AS Updates   Success Oct 15, 2013 23:16:07 CDT
    You will see an event in the event viewer if the email was sent.
    I have a test account with gmail that I use along with my own exchange.
