Cloud Managed Networks
Email Notification for AP down in Central doesn't work
  • 1.  Email Notification for AP down in Central doesn't work
    Posted Jul 29, 2022 02:09 AM
    I integrated his new AP into Central for a customer.
    Now I wanted to set up the email notification.
    I have under "Global" at Alert&Events via "Config" at ALERT SEVERITIES & NOTIFICATIONS
    "Access Point" the item: AP Disconnected selected, entered the group and also the site,
    Notification Options on: Email.
    Default recipes set up and also my email address under other recipes.
    But I don't get any mail that there is an AP down.
    In addition, I have the item under ALERT SEVERITIES & NOTIFICATIONS under "Site":
    Set up Aggregated Device Disconnections.
    But that doesn't work either. I don't get an email.
    Where am I making a mistake?
    Thomas
  • 2.  RE: Email Notification for AP down in Central doesn't work
    Posted Jul 29, 2022 03:14 AM
    I see under: Global:
    Events:
    Alerts:
    When i look under the specific Group:
    Events:
    Alerts:
    there is no Entry.
    Since the Alert configuration happens under the group and nothing appears under Alerts, the question is why nothing is displayed there.
    And if nothing is entered under Alerts in the group, then the email notification cannot work either
    Thomas
  • 3.  RE: Email Notification for AP down in Central doesn't work
    Posted Jul 29, 2022 04:46 AM
    I have found my mistake. If you set the alerts under group and site, it doesn't work. If you only set up the alerts under Site, the email notification works at AP Down.
    Thomas
  • 4.  RE: Email Notification for AP down in Central doesn't work
    Posted Jul 29, 2022 06:49 PM
    Thanks for sharing the info.
