Training, Certification & Career
last person joined: 12 days ago
Get more information about the HPE Aruba Networking technical training and certification programs. Network with your colleagues to improve your career, and post job availability for network engineers within your organization.
EMEA Airheads On Demand Tech Webinars
This thread has been viewed 47 times
  • 1.  EMEA Airheads On Demand Tech Webinars
    Posted Jul 18, 2016 04:52 AM
    The Airheads Technical Webinars are regularly scheduled live online technical discussions conducted with channel/customer SE’s to help them further their understanding of Aruba technology and solutions. Topics to be discussed will vary based on interest at the time or relevant Aruba technological topics or announcements.
    ACCESS OUR ON DEMAND WEBINARS
    Airheads Tech Talks: Advanced Clustering in AOS 8.x
    Webinar Recording & Slides
    Clustering is a new feature introduced in AOS 8.0 that enables seamless roaming of clients between APs, hitless client failover and load balancing of users across Mobility Controllers in the cluster. This solution provides the configuration required to create a cluster of Mobility Controllers that are managed by the same Mobility Master. Check out the recording
    CHECK OUT THE WEBINAR RECORDING
    AdvanceD Aruba Central
    During this webinar, we will cover a deep dive into Aruba Central and its features.Check out the recording
    Aruba AppRF – AOS 6.x & 8.x
    During this webinar, we will cover AppRF - a suite of application visibility and control features that are part of Aruba's Policy Enforcement Firewall. AppRF is a PEF feature that is designed to give network administrators insight into the applications that are running on their network, and who is using them. Check out the recording
    Switch Stacking – ArubaOS Switch
    During this webinar, we will discuss how the ArubaOS switch virtualization technologies can deliver high-performance and highly available switching while simplifying management and lowering costs.
    Policy-Based Routing in the branch – ArubaOS 8.x
    Generally, routing is done based on the Destination address. Policy-Based Routing (PBR) helps route the traffic based on L3-L7 information. This, in turn, helps to make use of all the available uplinks. To make use of this feature, we need to define a couple of Elements like PBR Nexthop, Route ACL, and attach points. Join the webinar to learn how.
    LACP and distributed LACP – ArubaOS Switch
    During this webinar, we will discuss how IEEE standard 802.3ad and its implications allow third-party devices such as switches, servers, or any other networking device that supports trunking to interoperate with the distributed trunking switches (DTSs) seamlessly.
    Introduction to AirWave 10
    During this webinar, we will discuss AirWave 10, a new software build that lets us streamline code, add performance, clustering.
    Virtual Switching Framework – ArubaOS Switch
    During this webinar, we will discuss how Virtual Switching Framework (VSF) allows supported switches connected to each other through Ethernet connections (copper or fibre) to behave like a single chassis switch.
     Aruba Central with Instant AP
    During this webinar, we will cover the Central platform which provides a standard Web-based interface that allows you to configure and monitor multiple Aruba Instant networks / Switches from anywhere with a connection to the Internet.
    AirGroup profile changes across 8.1 & 8.2 – ArubaOS 8.x
    In this presentation, we will discuss how AirGroup configurations have changed to support hierarchical configuration in release 8.2. AirGroup configs will now be profile based and can be applied at any node.
    Getting Started with the ClearPass REST API
    In this presentation, we will explore the REST API as the ClearPass API integrations and further developments are more focused to REST API than the other existing API services like xml-rpc, SOAP, etc.
    AP DISCOVERY & DEPLOYMENT POLICY - ARUBAOS 8.X
    During this webinar, we will discuss how starting from ArubaOS 8.2.0.0, selected APs can run in both controller-based mode and controller-less mode and the implications tied to that.
    Layer-3 Redundancy for Mobility Master - ArubaOS 8.x
    In this webinar, we will discuss the L3 Redundancy Requirement which primarily comes from customers who want to handle the complete Data Center Failure during natural disasters or other catastrophic events.
    Manage Devices at Branch Office (BOC)
    In this webinar, we will discuss how branch controllers work and run through different deployments examples in 6.x and 8.x.
    What does AirMatch do differently?
    The existing channel and power assignment functions in ARM support channel scanning, channel assignment and power adjustments, locally. Decisions are made locally at the AP without looking at the entire network. Thanks to the dynamic machine learning techniques, AirMatch centralises this function in the Mobility Master while dynamically learning the network and adapting the RF planning for the entire network. Check out What does AirMatch do differently?
    Configuring different APIs in Aruba 8.x
    During this on-demand webinar, we will run through different API types and cases: configuration APIs (REST API), context APIs (NBAPIs), SDN APIs and explain how to make API calls via CLI.
    Aruba Remote Access Point (RAP) Troubleshooting
    During this on-demand webinar, we will be debugging Aruba RAP commands, run through troubleshooting and logs and tackle RAP clusters.
    Multi-zone AP and Centralized image upgrade
    During this on-demand webinar, we will cover basic requirements and supported topologies for Multizone AP, how to bring up APs in multi-version and how the AP's image upgrade differs in 8.x.
    Bringing up an Aruba MM, MD & APs
    During this on-demand webinar, we will cover how to bring up an Aruba MM, MD and APs and also go through some basic troubleshooting commands.
    How Licensing Works in ArubaOS 8.x
    During this on-demand webinar, we will cover an overview of ArubaOS 8.x Licensing from Supported/ Unsupported Topology to Server Failover behaviour and license generation and transfer.
    ARUBA 8.X ARCHITECTURE OVERVIEW & UI NAVIGATION
    During this on-demand webinar, we will run through the 8.x Architecture configuration model and share some UI navigation features such as managed controllers and spectrum monitoring, geolocation and maps.
    ARUBA INSTANT AP- VPN TROUBLESHOOTING
    This webinar will cover the IAP-VPN architecture which includes the following two components: IAPs at branch sites and controller at the datacenter.
    ArubaOS - Cluster Manager
    This webinar covers ArubaOS' Cluster Manager, a combination of multiple managed devices working together to provide high availability to all the clients and ensure service continuity when a failover occurs.
    Aruba Clarity. Because a Wi-Fi Problem's Often Not a "Wi-Fi" Problem
    Today, most mobile connectivity issues are quickly attributed to “bad Wi-Fi”. Very often it may not be a wireless or RF related issue at all. With Aruba Clarity, IT organisations now have visibility into non-RF metrics not only giving them end-to-end visibility into a wireless user experience, but also the ability to foresee connectivity issues before users are even impacted.
    ClearPass Extensions and how they can help
    Webinar Recording+ Slides
    ClearPass Extensions allow ClearPass to integrate with multiple enterprise services to cover dynamic real-time requirements like automatic guest registration and MDM integration. Microsoft Intune, McAfee ePolicy Orchestrator are some examples of integrations achieved using ClearPass Extensions.
