Enable a controller license in AOS8.5
  • 1.  Enable a controller license in AOS8.5
    Posted Aug 06, 2019 12:15 PM
    I upgraded a 7005 controller from AOS 6.4 to AOS 8.5 standalone mode. I can't enable the licenses using the CLI command "license-pool-profile-root" even in the /mm directory. The command is not supported. It works with the GUI but I have lots of controllers and prefer CLI.  I would appreciate any advice on how to use CLI if possible or why it's not possible.
    Thanks.
  • 2.  RE: Enable a controller license in AOS8.5
    Posted Aug 06, 2019 11:28 PM
    From the (MM) [mynode]# prompt or if this is a standalone or MCM controller, you should be able to simply add the license by using the following command from the CLI prompt of the MM, standalone, or MCM master.
    # license add <paste license key here)
    You can then see the licenses using the following command
    (MM) [mynode]# show license
    I hope this helps,
