Cloud Managed Networks
Enable broadcast filtering block Epson Scanner
  • 1.  Enable broadcast filtering block Epson Scanner
    Posted Nov 18, 2018 03:41 AM
    hi folks,
    need some help after enabling broadcast filtering (ARP) my epson multifunction printer (i think it's WSD function) can't be found on windows add printer wizard. anyone know which option i've to enable on airgroup ?
    Thank you
  • 2.  RE: Enable broadcast filtering block Epson Scanner
    Posted Nov 18, 2018 04:58 PM
    I would definitely turn on Airgroup (and the airprint service).
  • 3.  RE: Enable broadcast filtering block Epson Scanner
    Posted Nov 19, 2018 05:30 AM
    :( airprint doesn't help, i've turn on airgroup and airprint option. the printer can be found by mac computer but not windows computer, i think each of them using different protocol.
  • 4.  RE: Enable broadcast filtering block Epson Scanner
    Posted Nov 25, 2018 10:11 AM
    I would also try with DLNA, as the Microsoft computer won't use apple's bonjour protocol.
    If that doesn't work then I guess you have no option but to disable broadcast filtering.
  • 5.  RE: Enable broadcast filtering block Epson Scanner
    Posted Nov 28, 2018 10:19 PM
    DLNA already enabled at airgroup, if i disable broadcast filtering the scanner works but i dont want to sacrifice the others wireless performance.
    I see there's an option to "add new services" at airgroup, how do i add WSD scan to this new services ?
