Enable channels
  • 1.  Enable channels
    Posted Jun 13, 2016 05:07 PM
    I've got an AP I placed on channel 124 (power 1) but in the access point monitoring list it says it was moved to 52 because of an unsupported channel.
    In the regulatory domain profile, I've enabled all channels.
    (Aruba-Master-DC-35I) (AP name "NewMaster-Test") #show ap regulatory-domain-profile default
    Regulatory Domain profile "default"
    Parameter Value
    Country Code US
    Valid 802.11g channel 1
    Valid 802.11g channel 6
    Valid 802.11g channel 11
    Valid 802.11a channel 36
    Valid 802.11a channel 40
    Valid 802.11a channel 44
    Valid 802.11a channel 48
    Valid 802.11a channel 52
    Valid 802.11a channel 56
    Valid 802.11a channel 60
    Valid 802.11a channel 64
    Valid 802.11a channel 100
    Valid 802.11a channel 104
    Valid 802.11a channel 108
    Valid 802.11a channel 112
    Valid 802.11a channel 116
    Valid 802.11a channel 120
    Valid 802.11a channel 124
    Valid 802.11a channel 128
    Valid 802.11a channel 132
    Valid 802.11a channel 136
    Valid 802.11a channel 140
    Valid 802.11a channel 144
    Valid 802.11a channel 149
    Valid 802.11a channel 153
    Valid 802.11a channel 157
    Valid 802.11a channel 161
    Valid 802.11a channel 165
    Is there another reason that would not stay on 124? There are no DFS/Radar events.
  • 2.  RE: Enable channels
    Posted Jun 13, 2016 05:15 PM
    What AOS version? Also if you run the following. While 124 may be allowed on your controller, the specific AP types also have their own allowed channels, of which 124 doesn't appear to be allowed on the AP-124. For me this is on AOS 6.4.4.6
    (Aruba7005) #show ap allowed-channels country-code US ap-type 124
    Allowed Channels for AP Type 124 Country Code "US" Country "United States"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11
    802.11a (indoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 132 136 140 149 153 157 161 165
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11
    802.11a (outdoor)        36 40 44 48 52 56 60 64 100 104 108 112 116 132 136 140 149 153 157 161 165
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (indoor)   36-40 44-48 52-56 60-64 100-104 108-112 132-136 149-153 157-161
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (outdoor)  36-40 44-48 52-56 60-64 100-104 108-112 132-136 149-153 157-161
    802.11a (DFS)            52 56 60 64 100 104 108 112 116 132 136 140
    (Aruba7005) #
  • 3.  RE: Enable channels
    Posted Jun 21, 2016 07:53 AM
    these are all AP215s. I see that 120-128aren't allowed.
    AOS version 6.4.3.7
    thanks!
  • 4.  RE: Enable channels
    Posted Jun 21, 2016 08:12 AM
    Don't forget you can grab the latest DRT files from support and add them to your controller (no reboot needed) which may allow these channels to operate in the future. Right now, as of AOS 6.5, I don't see those channels on the 215, but standby for mid-July as we will be adding support for new channels and once approved, the new DRT file will allow those channels to work on the 215 (likely not on any 125s though).
