I think found the issue.
Devices behind silverpeak was acting as a router which redirect the traffic.
Reason why I didn't saw any return traffic.
Original Message:
Sent: Feb 20, 2023 11:09 AM
Subject: enable inter-VLAN routing on edgeconnect
Hi Enzo,
On my ECOS 9.2.2 testbed it works fine. Client on VLAN 2 can reach client in VLAN 4 and back. No need to configure anything specific. Just make sure the LAN side hosts have the EdgeConnect interfaces as their default gateway.
The "Local/Static" tab on your Routes page won't have the local entries, but the tab "All" will have them as "Auto" entries.
From the EC GUI you can make a packet capture. Make sure you select both LAN interfaces as shown in attached screenshot
Original Message:
Sent: Feb 20, 2023 10:31 AM
Hey,
Performing new instalation with a client.
I want to do vlan routing on the samen devices.
Edgeconnect has 1 lan port with several vlan on it configured.
Some with DHCP which is the edgeconnect itself, and some with a just a IP and subnet.
Issues is that I need a connection from vlan X to vlan Y on same edgeconnect.
Both vlan's are on the same edgeconnect.
I can ping the default gateway of vlan Y via a device in vlan X.
But I cannot ping a device in vlan Y.
When I'm on the same subnet I can ping the device in vlan Y.
Also on the edgeconnect ping tool I can ping devie in vlan Y.
So how can I enable inter vlan routing?
In the routes table I don't see any routes in local. (see attachment).
