Enable OKC with the Validate PMKID option
  • 1.  Enable OKC with the Validate PMKID option
    Posted Mar 03, 2015 10:50 AM
    How do I enable OKC with the Validate PMKID option on a Instant cluster?
  • 2.  RE: Enable OKC with the Validate PMKID option
    Posted Mar 03, 2015 11:42 AM
    okc is an option when you enabled wpa2 enterprise as the with method
  • 3.  RE: Enable OKC with the Validate PMKID option
    okc is an option when you select wpa2 enterprise
  • 4.  RE: Enable OKC with the Validate PMKID option
    Posted Mar 03, 2015 11:59 AM
    It is possible with WPA2 only. please go through the following snapshot.
    Please feel free for any further help on this.
  • 5.  RE: Enable OKC with the Validate PMKID option
    Posted Mar 03, 2015 12:16 PM
    So when I do this it breaks authentication for apple devices, from what I have read it says to enable OKC with the validate PMKID option to allow apple devices to authenticate.  I see the box for OKC but I dont see anything for PMKID
  • 6.  RE: Enable OKC with the Validate PMKID option
    Posted Mar 04, 2015 08:05 AM
    Agarner, the "Vaidate PMKID" option is applied silently in instant when OKC is enabled.
  • 7.  RE: Enable OKC with the Validate PMKID option
    Posted Mar 03, 2015 12:02 PM
    It is possible with WPA2 enterprose security only. for your ref:
