Hi joseph,
I'm using IAP 225 with instant version 6.4.3.4 and I have seen that this release supports MCS 0-9 configuration for each stream, with commands:
supported-mcs-set and vht-support-mcs-map in a wlan profile
The question is that I have configured MCS 2 or 3 for each one of three streams, but I don't see any changes at wlan profile configuration, the command is not shown at config.
Is there some way to check for each stream which valid MCS is available??.
Could also check is a client 11ac is using 20, 40 or 80 Mhz channel??.
Thank you
