Enable Roaming
This thread has been viewed 46 times
  • 1.  Enable Roaming
    Posted Sep 25, 2023 09:55 AM
    Hello Experts,
    I would like to enable fast roaming for group of AP which already created with around 25 AP and 10 SSIDs.
    To active this I did these steps:
    Configuration--->System--->Profiles--->Wireless LAN--->802.11R
    Create profile then On virtal AP assigined to SSIDs which I want.
    I would like to know do I need to do anything else or not ?
  • 2.  RE: Enable Roaming
    Posted Sep 25, 2023 12:47 PM
    I'd recommend taking a look at the RF and Roaming Optimization for Aruba 802.11ac Networks document.  Client support is going to be hit-or-miss.
    Carson Hulcher, ACEX#110
  • 3.  RE: Enable Roaming
    Posted Sep 25, 2023 08:29 PM
    yes you need to check your client population for fast roaming.
    Here is ipad support
    https://support.apple.com/en-au/guide/deployment/depf9bb7e412/1/web/1.0
  • 4.  RE: Enable Roaming
    Posted Sep 26, 2023 02:02 AM
    Hello Ariya,
    Thanks for sharing this. I will keep in mind.
    Best,
  • 5.  RE: Enable Roaming
    Posted Sep 26, 2023 02:01 AM
    Hello Carson,
     I will take a look and I will give you the result.
    Best
