Enable SSH access to campus AP on 7030 controller?
This thread has been viewed 37 times
  • 1.  Enable SSH access to campus AP on 7030 controller?
    Posted Jan 24, 2017 09:55 AM
    Hi everyone.
    Is it possible to enable SSH access to campus AP (Aruba 7030 controller) and if so how do you do it?
    I have found out that you can enable Telnet access to the APs by editing the AP system profile but I would like to use SSH if possible.
    Best regards,
    Petter
  • 2.  RE: Enable SSH access to campus AP on 7030 controller?
    Posted Jan 24, 2017 09:57 AM
    Only telnet is supported, unfortunately.  It is also very rare to use that feature.
  • 3.  RE: Enable SSH access to campus AP on 7030 controller?
    Posted Nov 01, 2019 10:29 AM
    You would think that it would be rare but a number of my support calls end with support wanting to see console on the access point so unless it is easy to access the console port you will want to be able to remote in to the access points.
  • 4.  RE: Enable SSH access to campus AP on 7030 controller?
    Posted Nov 01, 2019 10:41 AM
    There are crucial things that you can see at the console, that you cannot see while telnetted into an AP.  Those are two different things.
    Closing this thread because it is two years old.
