Enabling control plane security
  • 1.  Enabling control plane security
    Posted Oct 28, 2014 10:46 AM
    Currently I have an Aruba 3200 (non XM) that tunnels all WLAN traffic to the controller.  I want to switch to bridge forwarding.  I need control plane security enabled and for the APs to re-join and get accepted by the controller for bridge forwarding correct?  I will enable auto-cert provisioning so that any AP that contacts my controller will be accepted.
    If I need to enable control plane security I should plan for downtime, correct?  If so, any idea how long the whole process should take? Just one 3200 and 18 AP-105s in this network.
  • 2.  RE: Enabling control plane security
    Posted Oct 28, 2014 11:08 AM
    Correct
    You should plan for a downtime for 30-45 minutes because APs need to reboot after you enabled CPSec, it may take less then that but just in case..
  • 3.  RE: Enabling control plane security
    Posted Oct 28, 2014 11:11 AM
    This is based on an M3 controller but this gives you an idea:
    2014-10-28 11_10_21-www.arubanetworks.com_wp-content_uploads_MControllerVRDV9.pdf.png
