Enabling Endpoint Classification
  • 1.  Enabling Endpoint Classification
    Posted Sep 22, 2017 10:02 AM
    Hi
    Quick question about enabling endpoint classification
    I have a CPPM cluster - two nodes.  Currently I have profiling enabled on both nodes. One handles Wifi and the other LAN and will cover each other on failure.  Should it be enabled on both nodes?
    Is there any issues if I leave it on both?
  • 2.  RE: Enabling Endpoint Classification
    Posted Sep 22, 2017 12:09 PM
    Do you have a VIP configured between the nodes?
    Get Outlook for iOS
  • 3.  RE: Enabling Endpoint Classification
    Posted Sep 22, 2017 12:16 PM
    Hello there
    Yes - I have a VIP, I use it for the captive portal at the moment.
    M
  • 4.  RE: Enabling Endpoint Classification
    Posted Sep 22, 2017 12:21 PM
    Then just use the VIP for the profiling
  • 5.  RE: Enabling Endpoint Classification
    Posted Sep 22, 2017 12:24 PM
    my VIP is xx.xx.80.1
    and that points to the publisher at 70.9
    so the advice would be to untick endpoint classification on the subscriber 70.8
