last person joined: 11 hours ago
Enabling Password Configuration Control ArubaOS
This thread has been viewed 24 times
  • 1.  Enabling Password Configuration Control ArubaOS
    Posted Mar 21, 2022 12:38 PM
    When I enable "password configuration-control" on an ArubaOS switch managed via central I'm unable to SSH to the switch. As soon as I disable "password configuration-control" I'm able to SSH to the switch again.
    A message appears when enabling "password configuration-control" saying that web management and the REST api will be disabled when it's enabled. Not sure if this is related but mentioning it anyway..
    Has anyone else encountered this?
    Cheers
    James Whitehead
  • 2.  RE: Enabling Password Configuration Control ArubaOS
    MVP GURU
    Posted Mar 21, 2022 06:14 PM
    Where are you configuring this in Central?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Enabling Password Configuration Control ArubaOS
    Posted Mar 22, 2022 05:13 AM
    Good point. I'm not. I'm doing it via the CLI in support mode as Central doesn't support the functionality (and TAC advised me to).
    I'll recreate the post in the wired forum. Thanks for the reply.
    James Whitehead
  • 4.  RE: Enabling Password Configuration Control ArubaOS
    MVP GURU
    Posted Mar 22, 2022 07:12 AM
    I would follow this as well. It didn't work for me until I set the minimum password length to 8. Default is Zero, but needs to be at or higher than the complexity elements: https://community.arubanetworks.com/blogs/esupport1/2020/09/30/password-control-configuration-pvos
    Dustin Burns
