Enabling routing in OmniAccess 4306G
  • 1.  Enabling routing in OmniAccess 4306G
    Posted Nov 18, 2013 12:02 AM
    Hi Guys,
    How to enable routing in OmniAccess 4306G?
    Is it via interface vlan only or global as well? Thanks
  • 2.  RE: Enabling routing in OmniAccess 4306G
    Posted Nov 18, 2013 09:01 AM
    By default, any VLAN you create intervlan routing is enabled.  show interface vlan <id> should give the  status about if Routing is enabeld on that VLAN.
    Inter VLAN routing is not going to work until explicitly you provide "no routing" from the VLAN interface which can be viewed by "show running-config"
    Thx,
    Sriram
  • 3.  RE: Enabling routing in OmniAccess 4306G
    Posted Nov 18, 2013 10:02 PM
    Hi Sriram,
    I disable ip routing on all vlan interface but inter vlan routing still not working.
    Anything I still havent done? Thanks
  • 4.  RE: Enabling routing in OmniAccess 4306G
    Posted Nov 19, 2013 10:24 AM
    You need to enable ip routing for Inter VLAN routing to work.
    Configure terminal
    Interface vlan <id>
    ip routing
