Wired Intelligent Edge
Encrypt transmission data between two Aruba 2530
  • 1.  Encrypt transmission data between two Aruba 2530
    Posted Aug 29, 2018 06:53 AM
    How encrypt data transmission between two Aruba 2530 ?
    THX
  • 2.  RE: Encrypt transmission data between two Aruba 2530
    MVP GURU
    Posted Aug 29, 2018 08:32 AM
    By means of a VPN? please consider that Aruba 2530 are just gigabit ethernet switches (with very limited Layer 3 features, if any)...not VPN Firewalls.
  • 3.  RE: Encrypt transmission data between two Aruba 2530
    Posted Aug 29, 2018 02:06 PM
    MACsec or IPSec ?
  • 4.  RE: Encrypt transmission data between two Aruba 2530
    MVP GURU
    Posted Aug 29, 2018 07:51 PM
    @mietek wrote:
    MACsec or IPSec ?
    Is that relevant considering that Aruba 2530 is not able to support any of them?
  • 5.  RE: Encrypt transmission data between two Aruba 2530
    Posted Aug 30, 2018 04:30 AM
    MACSec is supported on the 2930M, 3810M and 5400R (for the 5400R on SmartRate or V3 modules).
    Check the ArubaOS-Switch Software Feature support Matrix 16.06 for a full overview of feature that are (or are not) supported on each switch model.
