Endpoint Authorzation with Aruba Activate
  • 1.  Endpoint Authorzation with Aruba Activate
    Posted Nov 09, 2017 08:47 AM
    We Authorize our Remote APs via an Aruba Activate Endpoint Context Server configuration in ClearPass. We just got some of the new AP-203R's. Unfortunately they are not noted properly in Activate for the default Aruba Activate Endpoint Context Server. If there an recommnded change to the Device Filter to allow the 203R's?
    Thanx - Eric
  • 2.  RE: Endpoint Authorzation with Aruba Activate
    Posted Nov 09, 2017 11:27 AM
    Add filter entries for the new J part numbers.
    JL1*,JL2*,3EM*,JW*,JY*,JZ*
  • 3.  RE: Endpoint Authorzation with Aruba Activate
    Posted Nov 09, 2017 12:20 PM
    So that filter is on the "Part" field? I thought it was on the "Part Description" field. ... Or is it both? Is there refernece material for this stuff?
    Thanx - Eric
