endpoint device dot1xing via AP ethernet port
  • 1.  endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 10:10 AM
    Need some help persuading dot1x to work via an AP ethernet port
    Got a client performing Peap/mschapv2 auth. plug into switch port and everything "just works" authenticating to our clearpass service
    Change to eap-tls same thing everything works
    Connect to wifi service all work
    Create new clearpass service just for dot1x via an AP 2nd ethernet port ( Different selection criteria)
    Plug same device into 2nd AP eth port ( I didn't do the AP config for this)
    All eap based auths fail. For windows client uncheck the validate server certificate box in the dot1x config... and the auths work
    We're not terminating eap auths on the controller, they all go to the same clearpass cluster as all other services. Eap based auth same as any other service
    So is there any magic that needs to be done on the controller  ?
    Rgds
    A
  • 2.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 10:21 AM
    Can you please share your config for the AP port ?
    You should able to use the same wired service (clearpass) and aaa profile you for your 802.1X wireless (controller)
    Pardon typos sent from Mobile
  • 3.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 10:41 AM
    You mean the attached?
  • 4.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 11:46 AM
    Can you also share the aaa profile and the access tracker your are getting ?
  • 5.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 12:02 PM
    The session log doesn't show much more than the auth alert .png file
  • 6.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 19, 2018 01:30 PM
    Everything looks good on the controller side.
    You mentioned that your wireless clients are able to authenticate with no
    issues using 802.1X , I suggest you take a look at how the wireless profile
    is configured in the WIndows and match the same config on your Wired
    profile.
    Looks like profile is not configured properly
  • 7.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 20, 2018 09:57 AM
    Sorry, have to disagree. We use an onboarding appliance that configures both wired and wifi eap based authentication. Same configurations work on ProVision,Aruba Switches,Comware and normal wifi connectivity. All these network devices use clearpass for authentication and "just work"
    The only thnig that doesn't is dot1x via wired port on this ap (93H)
  • 8.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 20, 2018 10:39 AM
    A couple of things:
    - Can you confirm the device is configured properly ? Root CA / RADIUS Cert
    - And also sure the certificate still valid in the onboard db
    - make sure you are using the same auth-type (EAP-TLS) you created for the other already working wired service
    - have you tried using another device ?
  • 9.  RE: endpoint device dot1xing via AP ethernet port
    Posted Apr 20, 2018 11:07 AM
    Whih device ? client?
    Not using aruba onboarding stuff, using Cloudpath
    If u mean clearpass service, copes with peap,ttls and tls
    Yup windows and macos
  • 10.  RE: endpoint device dot1xing via AP ethernet port
    Posted May 01, 2018 06:27 AM
    Sorted !!
    and it wasn't anything we did ... ish
    I' have a service on our 6.7.2 cppm cluster that uses a service specificc CA chain ( local PKI instructure). The service we created was at the bottom of our list of services.
    Lookint at the release notes for 6.7.3 one of the fixes  is
    #44257 A service certificate that was configured on one service was also applied to all the services below that service in the order of processing, even if they were configured with a different service certificate. This had caused requests to the lower services to be denied with the error “Unknown CA.”
    Guess what was happening .... as soon as we moved the cert abouve the one using our own PKI  things sprang into life
