Endpoints are Unknown
  • 1.  Endpoints are Unknown
    Posted Oct 22, 2013 01:32 PM
    I'm having a problem with my new ClearPass implmention where the majory of my Endpoints status is not being updated from Unknown to Known.
    This is causing MAC cacheing problems as everytime a guest re-connects to the server they have to then re-enter in their credentials.
    I can't explain why some are coming up as unknown while others are known.
    Is there a setting somewhere that im missing ?
  • 2.  RE: Endpoints are Unknown
    Posted Oct 22, 2013 01:34 PM
    Check your enforcement profile and see if there is a Post_Authentication action that updates the endpoint status to Known.
  • 3.  RE: Endpoints are Unknown
    Posted Oct 22, 2013 01:58 PM
    Thank You!
    That was my problem.  I had made my own enforcement policy and that did not include a post_authenticaiton of updating the endpoints.
  • 4.  RE: Endpoints are Unknown
    Posted Dec 10, 2013 08:50 AM
    Hi.
    By default status of endpoints in endpoint respository is unknown ri8??
    if we have to change the status to known, either we have to do it manually or with post authentictaion things ri8??
    cheers
    srikanth
  • 5.  RE: Endpoints are Unknown
    Posted Dec 10, 2013 08:51 AM
    You would use a Post_Authentication action of [Update Endpoint Known]
  • 6.  RE: Endpoints are Unknown
    Posted Dec 10, 2013 08:55 AM
    By default it will be unknown ri8??
  • 7.  RE: Endpoints are Unknown
    Posted Dec 10, 2013 09:02 AM
    Yes
