Endpoints discovered via SNMP scan to be automatically "Known"
  • 1.  Endpoints discovered via SNMP scan to be automatically "Known"
    Posted Oct 31, 2016 10:59 AM
    Hi!
    I´ve set up a subnet scan and SNMP configuration under "Profile Settings" for profiling the printer subnet. The printers all have static IP-addresses. My next step is to connect them to a 802.1X with Mac-auth-bypass switchport so I´d like them to be marked as "Known" as soon as they are profiled via the subnet scan so they can pass mac-auth.
    Anyone have suggestions on how to accomplish this?
    Cheers,
  • 2.  RE: Endpoints discovered via SNMP scan to be automatically "Known"
    Posted Oct 31, 2016 11:02 AM
    You can use Allow All MAC-Auth combined with authorization using the profile
    data.
  • 3.  RE: Endpoints discovered via SNMP scan to be automatically "Known"
    Posted Oct 31, 2016 11:11 AM
    So step one to use subnet scan while connected to a non-authentication port to collect the profile data.
    Step two connect it to the switchport with authentication and place it in the guest-VLAN via Allow all mac auth and also mark it as known in endpoint DB and then bounce it to be correctly assigned printer VLAN?
    I also want a guest to be able to connect to these switchport and get the guest-VLAN without being bounced off again. Maybe there´s a way to differentiate a guest from a previously profiled printer. I´ll give it a try.
  • 4.  RE: Endpoints discovered via SNMP scan to be automatically "Known"
    Posted Oct 31, 2016 02:02 PM
    That's correct
    You can put in place that if device is profiled as a computer then T that device will be placed on the guest but it will need to be bounced initially to get the profile information
    Get Outlook for iOS
