Hi.
Did you direct dhcp relay to clerpass server? Or did you enable Aruba Central Device Insight integration with Clearpass?
If Clearpass can't receive data about the client, it can't profile it.
Look int Clearpass profiling how to to get an idea.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Aug 17, 2024 07:32 PM
Subject: Endpoints not getting profiled in ClearPass - Aruba Central SSID
I have a new SSID created in Aruba Central for testing. I have a device that connects to the SSID via 802.1x. I have profiling enabled on the service and yet the endpoint remains unprofiled in ClearPass. It should get profiled at that most basic level but it says "Profiled = No" in ClearPass. What could I be doing wrong, there is not much configuration I have done besides a basic 802.1x wireless service with Profiling enable. Accounting is enabled and working.
