Network Management
Enet0 and Enet1 don´t bring up
  • 1.  Enet0 and Enet1 don´t bring up
    Posted Aug 18, 2017 01:23 PM
    Best regards
    I need help with the AP-225,  the interfaces Enet0 or Enet1 never up.
    I test the patch core, POE, Sw, and are okey.
    Please see the atached file.
    i think the possible cause is the firmware,whats is the form to upgrade via usb by CLI?
    being attentive
    Steven
    Attachment(s)
    txt
    AP.txt   7 KB 1 version
  • 2.  RE: Enet0 and Enet1 don´t bring up
    Posted Aug 18, 2017 02:04 PM
    Is this a new access point?  Is it an AP-225 or an IAP-225?
  • 3.  RE: Enet0 and Enet1 don´t bring up
    Posted Aug 22, 2017 08:39 AM
    HI Cjoseph
    Yes, it is new AP-225, only i up the backup of before AP.
  • 4.  RE: Enet0 and Enet1 don´t bring up
    Posted Aug 19, 2017 09:16 AM
    If it is an IAP-225, it is an Instant AP and you will need to configure it by joining your computer to the SSID (named "instant" I think?) it creates when you plug it in. It will not show up in your controller like a campus AP (standard AP-225) would. You can then convert it to a standard campus AP and it will show up on your controller.
  • 5.  RE: Enet0 and Enet1 don´t bring up
    Posted Aug 22, 2017 08:48 AM
    Hi rsinclair
    The AP don´t show the instant SSID.
  • 6.  RE: Enet0 and Enet1 don´t bring up
    Posted Aug 22, 2017 09:30 AM
    I explain more, the AP 225 its new, the first time that i plug the AP all good, show SSID instant and get IP with the local interface.
    the friday i upload the backup of previous AP-225, and the AP don´t up the interface again afther this upload.
    I reset to factory default and don´t bringup the interfaces.
  • 7.  RE: Enet0 and Enet1 don´t bring up
    Posted Sep 27, 2017 05:07 PM
    Hi
    i found the solution:
    1. update the version to most recent.
    2. via CLI i stop the boot process and assign the ip address.
    3. After this process the ssid will be visible.
    The Enet 0 or Enet 1 is active after this process
  • 8.  RE: Enet0 and Enet1 don´t bring up
