enforce-dhcp not working - 6.4.3.7
  • 1.  enforce-dhcp not working - 6.4.3.7
    Posted Apr 07, 2016 09:25 AM
    I've recently started setting up a small WLAN for fixed-ip (static) devices.  I've duplicated my AAA profile and added the "enforce-dhcp" option to it and use it only for my static WLAN.
    So using a fixed-ip that comes from the DHCP server works ok:
    # show user-table  ip 1.1.1.2 detail | include DHCP
    Address is from DHCP: yes
      DHCP role: n/a, Default role: cp-logon, Cached role: n/a
    But when I set the same system (MBair) with a static IP address, it still continues to work, incorrectly stating that the Address is from DHCP.  I've verified that the DHCP server did not hand out this address.
    # show user-table  ip 1.1.1.3 detail | include DHCP
    The DHCP address shows up in the route-cache, but the static IP does not.  Interestingly though, even after setting the static and clearing the route-cache, it still remains.
    # show datapath route-cache table | include f4:f8:f5:fE:fF:fC
    1.1.1.2      f4:f8:f5:fE:fF:fC         2016  H
    #clear datapath route-cache 1.1.1.2
    I've never used enforce-dhcp in the past to be able to say if the new ArubaOS version isn't working or my concept isn't working.
    thanks
    mike
  • 2.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Apr 07, 2016 09:32 AM
    Please open a TAC case, so that they can investigate whether this is a bug or not.
  • 3.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Oct 13, 2017 11:26 AM
    Any news on this? We have the issue at a customer as well. Using Macbook with the option DHCP with manual address...
  • 4.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Oct 13, 2017 11:29 AM
    We were funnelled into upgrading to 6.5 for new hardware so the fix was incorporated there and into later 6.4 versions.. I don't have the bug id handy.
  • 5.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Oct 13, 2017 11:31 AM
    We are using 6.5.1. but it is still possible to change the IP on a Macbook.
  • 6.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Oct 13, 2017 11:37 AM
    I can see the fix in 6.4.4.10. I will double check the software version.
  • 7.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Oct 13, 2017 11:39 AM
    I looked back through my email and found the case.  It was assigned Bug ID: 140731.  (I honestly haven't checked on it in 6.5 as I've been chasing much more important bugs :(  )
    Bug ID
    Description
    Component
    Platform
    Reported Version
    Resolved in Version
    140731
    Symptom: DHCP enforcement in the AAA profile failed in a controller for some clients connecting with static IP addresses. The fix ensures that the traffic from all clients with static IP address is blocked when DHCP enforcement is enabled in the AAA profile. Scenario: This issue occurred when MAC-OS clients with static IP address connected to a controller on which the DHCP enforcement was enabled in the AAA profile. This issue was observed in controllers running ArubaOS 6.4.3.x.
    Controller- Datapath
    All platforms
    ArubaOS 6.4.3.7
    ArubaOS 6.4.4.10
  • 8.  RE: enforce-dhcp not working - 6.4.3.7
    Posted Nov 02, 2017 09:56 AM
    Hi Mike,
    is it possible to track if the fix is included in the 6.5 version?
    Thanks a lot.
