"enforce-dhcp" on IAP
  • 1.  "enforce-dhcp" on IAP
    Posted Oct 21, 2016 07:06 PM
    On IAP, do we have anything like "enforce dhcp" that we have on the controllers?
    I dont want to have clients with static IP connect on the SSIDs advertised by the IAP.
  • 2.  RE: "enforce-dhcp" on IAP
  • 3.  RE: "enforce-dhcp" on IAP
    Posted Dec 10, 2019 04:56 AM
    If I have two clusters with same SSID, could enforce-dhcp be a problem for clients L2 roaming between clusters?
