Enforcement Policy for different Users over the same Service / Accounting / re-authentication
  • 1.  Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 24, 2015 10:17 AM
    is it possible to use different enforcement policys over the same service?
    I have a service role mapping with nas_id and I need two diffrent policys in this service.
    In the service settings I just can add one fixed enforcement policy.
    Do I need for all diffrent enforcement mappings one service?
    Second thing, can someone explain me why there was always a re-auth?
    Attached file.
    Thank you
  • 2.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 24, 2015 06:21 PM
    What conditions are different between the two groups of users/devices that you want to test for?
  • 3.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 25, 2015 04:25 AM
    enforcement profile session limit should be diffrent. User A 5 sessions User B 20 sessions.
    Thank you
  • 4.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 25, 2015 07:16 AM
    You create two different radius Enforcement Profiles:  One that sends one session limit, and another one that sends a different session limit.  Then you create a radius enforcement policy that looks for a username and sends a specific limit and another line that looks for a different username and sends a different limit:
  • 5.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 26, 2015 05:13 AM
    I try this with authentication username but the enforcement is not listed after login with the user.
    I just solved it now with an new service for this username an add the policy there directly.
    Thnak you very much for reply.
    Marco
  • 6.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Aug 27, 2015 12:22 AM
    You can simply make it in one service by,makeing Role tagging for the 2 diffrent users for example :
    User X--Role-->10 Session
    User Y--Role-->15 Session
    after map the roles after that In enforcment policy add the Condition Rules:
    Tips-->Role-->Equal-->10 Session----take action which is Enforment profile of 10 session
    Tips-->Role-->Equal-->15 Session----take action which is Enforment profile of 15 session
    Try this it will work
  • 7.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Sep 03, 2015 06:31 AM
    I try but doesn´t work:
    Role for unlimited Logins:
    (Radius:IETF:User-Name  EQUALS  booking)
    FOR THE OTHER ROLES I MAP ROLE_ID BUT WHERE IS THE ROLE ID FOR MY NEW ROLE?
    [Booking]
    Enforcement:
    (Tips:Role  EQUALS  [Booking])Mobile Session Limit - unlimited Active
    Access Tracker:
    Service:
    Mobile
    Authentication Method:
    EAP-PEAP,EAP-MSCHAPv2
    Authentication Source:
    Local:localhost
    Authorization Source:
    [Guest User Repository]
    Roles:
    [Guest], [Mobile], [User Authenticated]
    WHERE IS THE ROLE Booking?
    Endpoint:Usernamebooking
    Expire-Time-Update:GuestUser0
    Expiry-Check:Expiry-Action0
    Post-Auth-Check:ActionDisconnect
    Post-Auth-Check:ActionDisconnect and Block Access
    Radius:IETF:Session-Timeout0
    Session-Check:Active-Session-Count5
  • 8.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Sep 03, 2015 06:42 AM
    Looks like your enforcement isnt configured to return a role.
    Tim
  • 9.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Sep 03, 2015 06:47 AM
    This is my enforcement policie:
    Name:
    Guest Access Policy MOBILE
    Description:
    Enforcement policy for standard mobile access features
    Enforcement Type:
    RADIUS
    Default Profile:
    [Deny Access Profile]
    Rules Evaluation Algorithm:
    First applicable
     ConditionsActions
    1.(Tips:Role  EQUALS  [Booking])Mobile Session Limit - unlimited Active
    2.(Tips:Role  EQUALS  [Mobile])Mobile Session Limit - 5 Active
    3.(Tips:Role  NOT_EQUALS  [Mobile])[Deny Access Profile]
    I think the problem is that my username booking not map to the role Booking, isn´t it?
  • 10.  RE: Enforcement Policy for different Users over the same Service / Accounting / re-authentication
    Posted Sep 03, 2015 08:32 AM
    Looks like the role mapping is working but you don't have any RADIUS enforcement profile either or the rules.
    Tim
