Greetings, I have created an enforcement profile that sends a Cisco interface description command when a dot1x athenticated device gets plugged into a switch. The command puts the hostname/IP description of the computer on the switch interface. If I move the device to a different port, it will do the same on the new port, but the previous port still is labeled with the same description. Does anyone know how to have Clearpass remove the old port description when the device is moved to a new port?
Here is the enforcement profile attributes command I am using to label the port:
config terminal
interface %{Radius:IETF:NAS-Port-Id}
description CP-%{Host:Name}-%{Radius:IETF:Framed-IP-Address}
Here is the result on the switch:
show int desc
Gi1/0/1 up Laptop-xyz 10.10.10.10
Gi1/0/2 down Laptop-xyz 10.10.10.10
