Entire Site AP105's appear on local but not on Master
  • 1.  Entire Site AP105's appear on local but not on Master
    Posted Nov 27, 2012 12:26 PM
    I have an entire site's AP105  (53 total) show up on the local M3 controller.... a few with 2IL but the concern is that none of those AP's show up on the master controller....
    I can ping the AP's from the Master
    Do I have a route issue ?? is the Master out of sync... we have a total of 1800 ap's and don't won't to reboot just yet...
  • 2.  RE: Entire Site AP105's appear on local but not on Master
    Posted Nov 27, 2012 02:53 PM
    if you mean they do not show when you click on access points from monitoring options then thats fine, if you mean that from ALL NETWORK option in master they are not included then, we need to know how your master/local are connected and is the link between them working perfectly ?
  • 3.  RE: Entire Site AP105's appear on local but not on Master
    Posted Nov 27, 2012 03:27 PM
    What is your output from "show master-local stats" on the local?
  • 4.  RE: Entire Site AP105's appear on local but not on Master
    Posted Nov 27, 2012 05:11 PM
    I have the same problem.  The local controller associate to master fine but AP-105s are not showing up at the master controller.  For instance, at the master,  you cannot “clear gap-db” of that local controller, but “show global-user-table list” will list users from that local controller.
    My controller AOS 6132, I am working on upgrade to 6135 because I hear it is probably bug in 6132 causing this problem (posted here somewhere)
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Should-all-APs-in-the-same-mobility-domain-be-populated-at-the/m-p/48168#M5269
  • 5.  RE: Entire Site AP105's appear on local but not on Master
    Posted Nov 27, 2012 06:42 PM
    The IL means that your AP is unlicenced and because of that is inactive
    You said your master didnt show but you can ping it?
    Do you have a local controller ?
    Where is the AP terminating?
    If its terminating on a local controller and if there is not enough license there then you will have that issue... you need to terminate that AP where you have licences...
