If you use Intune to enroll your certificates, you can easily add the Entra ID device id (or other field/attribute to select the device on) in the user certificate and have it available for lookup. That's what I have done.. and works.
Original Message:
Sent: Jul 18, 2024 06:18 AM
Subject: EntraID device lookup with TEAP
Hi guys,
I'm currently facing an issue using TEAP with certificates with EntraID autorization lookups.
To keep it short, when TEAP Phase 1 and 2 are successful, I need to retrieve the user AND device AD groups for my autorization policies. I don't have any problem with the user but I can't do it with the device as the TEAP-Phase-1-Username is truncated in the computed attributes (like sAMAccountName format: 15 characters + $ and there is not sAMAccountName equivalent in EntraID) and I can't use the certificates fields, either CN or SAN, because when Phase 2 is successful, the attributes contains only the user's certificate values.
When only phase 1 is successful, I can successfully retrieve the device's EntraID values and groups using the device certificate CN.
Therefore, I don't have any attributes (which I know) I can rely on to do the EntraID lookups for the device when Phase 1 & 2 are successful.
Have you faced a similar issue using TEAP-TLS with EntraID ? Is there any attributes I can match between Entra ID and ClearPass to retrieve a device ?
