last person joined: 10 hours ago
Entry and Access licenses simultaneously?
  • 1.  Entry and Access licenses simultaneously?
    Posted Jan 31, 2020 08:59 PM
    Hi gurus,
    I have a ClearPass 6.7 which is going to be upgraded to 6.8. My current Access licenses will be converted to Access licenses as well. Now I am going to install new Entry licenses because I don't need the entire set of features provided by the Access license. Then, am I allowed to install Entry licenses when Access licenses are already installed? Or I will get some kind of error or problem? Thanks in advance!
    Julián
  • 2.  RE: Entry and Access licenses simultaneously?
    Posted Jan 31, 2020 11:42 PM
    We can install Entry License, it will not prompt any errors.
    All Valid licenses we can install.
  • 3.  RE: Entry and Access licenses simultaneously?
    Posted Feb 01, 2020 08:48 PM
    OK, no errors, I understand. But can I have any problem? For example, let's say I have 100 Access licenses, 100 Entry licenses and 100 OnGuard licenses.
    1. Will I have unlimited TACACS+, Security Exchange and profiling because I have 100 Access licenses?
    2. Will I have any problem with OnGuard licenses? Because OnGuard requires Access, with only Entry licenses we can't use OnGuard.
    Julián
  • 4.  RE: Entry and Access licenses simultaneously?
    Posted Feb 01, 2020 10:50 PM
    You cannot have access and entry licenses in a cluster at the same time.
  • 5.  RE: Entry and Access licenses simultaneously?
    Posted Feb 03, 2020 08:19 AM
    OK, it makes much sense! Thanks!
    Julián
