Equivalent model for Ruckus AP...
  • 1.  Equivalent model for Ruckus AP...
    Posted Apr 18, 2019 02:56 AM
    Hi, can anyone tell me which aruba ap is equivalent the ruckus ap below, thanks in advance!
    1. Ruckus R310
    2. Ruckus R500
    3. Ruckus H320
  • 2.  RE: Equivalent model for Ruckus AP...
    Posted Apr 18, 2019 08:01 AM
    Maybe you could expand and check the Product Finder on this website to find a suitable AP for the Ruckus APs.
    https://www.arubanetworks.com/products/networking/access-points/
  • 3.  RE: Equivalent model for Ruckus AP...
    Posted Apr 18, 2019 11:56 AM
    R310 = Aruba AP-303 (lower cost, lower capacity) or 305 (slightly higher cost but far better performing for larger client loads)
    R500 = Same as above, but if you need two ethernet interfaces for a ceiling mounted AP, you would want the AP-325
    H320 - AP-303H if this is for hospitality use case
